Aftermarket wheel seals for CA, D10, D12 |
RMD
Joined: 07 Oct 2009 Location: Connecticut Points: 304 |
Topic: Aftermarket wheel seals for CA, D10, D12Posted: 16 Jan 2017 at 10:24am |
Has anyone else had this problem with aftermarket front hub seals on CA, D10, D12?
I was installing a new spindle and wheel bearings on my D12 yesterday. No matter what I tried I could not get the replacement seal to set on the spindle when using an aftermarket (ACS-1177) seal. I then tried an AGCO seal from the bearing kit I had for the other side of the axle and was able to install it without too much trouble. The ID of the aftermarket seal was visibly smaller than the AGCO part. Has anybody else had this problem? It looks like most of the seals of this type offered to for sale on the internet are the ACS1177 aftermarket part. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163 |
Posted: 16 Jan 2017 at 2:44pm |
I don't think that the Chinese got the conversion from inch to metric right. I finally started using a lip seal that is backwards from the OEM ones. I can't find a box with the number of what I've been using right now.
RMD
Posted: 17 Jan 2017 at 10:00am |
Bump
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88602 |
Posted: 17 Jan 2017 at 12:19pm |
this is what I had from several years ago on rebuild.
Inner seal 1.500 -2.506 7/16 lip seal CR 15141 –or 15142 that would be the ID, and OD, and the thickenss 7/16... bet the new seal is probably only 5/16. Chicago RAwhide is the manufacturer. can buy at bearing house.Edited by steve(ill) - 17 Jan 2017 at 12:21pm |
