AC B Lights
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: AC B Lights
    Posted: 12 Jan 2017 at 3:51pm
I have a  B converted to 12V with standard B headlights can I convert the lights to LED. If so what do I buy.  Can that be done to a 6 volt light on a B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 5:07pm
You can buy LED replacement bulbs for the 1196 backup light bulbs but they may not give off enough light. I had some universal round headlights on my B and found some 12V, 100W aircraft landing light sealed beams for them. Talk about putting out some light but the FAA said I had to file a flight plan every time I used them.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 6:03pm
Maybe go to NAPA store and ask if they have an LED replacement bulb to fit the socket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 3:25pm
Normal head lights on a car are about 55 watts... at 12 volts, that's about 5 amps each bulb.......... I would take the original bulb and look at Auto Zone or other and match up a LED bulb with the same base.. If your not worried about original case, they do sell aftermarket lights with LED bulbs inside that you could bolt on inplace.  If your question is, is it OK to use the 12 v LED, yes, any bulb would be OK... Somewhere around 55 watts.
