190xt
Bobo Husker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Topic: 190xt
    Posted: 07 Jan 2017 at 3:44pm
Finally got transmission and rear all back together. Due to what it cost for parts, Im hoping for so input on cheap power.....such as different turbo, injector pump but no serious motor work this year.
1965 190xt
Thank you in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 4:25pm
Ive read an HX35 or HE351 would be a good turbo. It has the original roosa master pump. Also read a pump off of a 7060 would help.
Any thoughts and what type of HP this could creat?
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 6:34pm
I'm going to put an hx35 on mine, it's a non wastegated turbo so it will look a little cleaner on it. Going to match it with a stock, but turned up pump and 7080 injector tips. Hoping for 150hp.
Why, I don't know. Why not? Lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 6:43pm
Yup read that on the injectors too. The pump really sounds interesting though also. Wondering if 150hp may even be low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 7:02pm
At least I think it will be a stock 190 pump,
Injpumped is doing the pump and injectors for me when I get the engine back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:05pm
If you need 150hp, buy a 150hp tractor. Then you can enjoy the comforts of a later tractor and not be concerned  about where the weakest link is in your 93hp tractor.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:07pm
Hard to make Wright with factory 150 hp tractor.
Weight
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:08pm
If your going to run 150 hp through a 90 hp tractor your going to be in the transmition and rear end again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:11pm
I should have clarified, this for pulling 6500# class.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 8:54pm
Then 150hp won't be no ways near enough.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 11:16pm
Originally posted by MACK MACK wrote:
If you need 150hp, buy a 150hp tractor. Then you can enjoy the comforts of a later tractor and not be concernedĀ  about where the weakest link is
in your 93hp tractor.    MACKĀ
Have a Versatile and IH 1486. So yes, I do have a 150+HP tractor. But I can still have a 150hp 190XT as a toy.
Tranny and pd have already been gone through. Won't be using it to plow 700 acres of hard clay every year. Heck, I'll be lucky to break 50 hours a year of use on it.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 7:13am
150 HP might be enough depending on whose sand box you are playing in!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 2:11pm
Good luck you may want to post down in the pulling forum they are knowledgable about pulling mods.
