Did A/C make a 7000 "Special" black belly????
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Topic: Did A/C make a 7000 "Special" black belly????
    Posted: 30 Dec 2016 at 8:42pm
https://springfield.craigslist.org/grd/5929058971.html
This 7000 black belly says "special"under the 7000 on the hood decal,has anyone seen that before? Could have been added by the PO but looks kinda official.
click on the C/L pics to enlarge.
Edited by hillmonkey - 30 Dec 2016 at 8:51pm
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 9:01pm
Yeah I've seen them.
KY poorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 10:08pm
Yes. We've got one.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 10:09pm
So....what's special about it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 10:11pm
Yeah, where are the special parts located?
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 11:48pm
8 bolt front hubs and heavy front end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 6:42am
Maybe they rode the SHORT truck from the factory! Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 8:14am
Whoever has it don't check their email, dam I hate that been looking for something like this
John D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John D Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:17am
A neighbor had one, like they said just the heavier front end if I recall correctly.
1964 D17 series 3
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:36am
I'm kinda thinking all the specials were black chassis. I've never seen a maroon special anyway. From what I've been told, the heavy front axle like the 7030 uses is about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 10:34am
http://www.ironsearch.com/Tractor/Allis-Chalmers/7000/2736036/Images.aspx?SK=TR-AC
Here is a old ad that was never taken down. 8 lug front w/o the "special" under the decal. either owner installed or "7000 only" decals were added one point. One also sold on C/L in ND a few weeks ago with 8 lug front and long axles but the ad is gone now and I did not notice the "special" so not sure on that one. Thanks for the response everyone.
also both above 7000s were/are black belly
Edited by hillmonkey - 31 Dec 2016 at 10:45am
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 11:29am
Would 1 of hose fit under a 200?
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 4:46pm
 1
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 6:04pm
I don't think that a heavy duty 7000 series front end could be fit onto a 200 very easily. However, I have seen a 210-220 style on a 190.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 7:01pm
In May 1978 the black belly 7000 went into production modified with the corporate Colors and acoustical cab to which were already installed in the larger 7020-7080 tractors in 1977. The cabin included the new console which eliminated the gear lever on  the floor other changes included Stadium lights electrically controlled outside mirrors luxury seat and other minor improvements. The most significant change was a power shift. The clutching function previously handled by dry engine clutch was now controlled  by the lower range (underdrive) hydraulic clutch in the power shift. Inching or loading starting all occurred in the underdrive for safety and longer clutch life. The dry engine clutch was replaced by a torque limiter which reduced power-train shock loads.  There was no gear ratio or Speed changes. It's 301 cubic inch 649T 6 cylinder 4.9 liter turbocharged power plant was basically unchanged and the PTO horsepower remained at  106.44. The tractor was not retested. Even with all these changes and improvements the 7000 still lack many features found on the larger tractors which limited its Acceptance in the market place. The black belly 7000 remained in production a short 13 months from May 1978 through June 1979. It was replaced with a more modern 7010 which was originally planned for this horsepower slot in 1972.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 12:43am
My dad bought one of the last 7000's. It was delivered on june 12 1980. It had all the best features, heavy front, 38 in rears, deluxe cab, but it had no "special" decal.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 6:25pm
I can't be sure on the dates, but the special tractors were a batch run the company built with the same specs  and reduced the price somewhat.   The late 7000's had the option of the hd front axle whether it was a special or not.   Somewhere in the cobwebs of the memory it seems that out of the Columbus, Ohio  branch Ed Swingle (later the only AC guy who co-founded Agco after the AC demise) may have had something to do with this as to a special dealer order and discount run of units.
The elimination of the dry clutch was a major price reduction of the 7000.  A lot of the savings were blown due to a field campaign to fix the tranny brake.  A properly set wet clutch 7000 operated well, especially after the oil warmed up.  In the frozen north yankee land it was a different story.. the drag on the wet clutch made the tranny hard to get out of gear even if the brake let one shift into gear.   The tractor with the wet clutch did make it into a great hay baling tractor as the elimination of the release brg and clutch pressure was easier on the left leg and pocket book  as clutch failures about went away.
