Allis B Creeper Drive?
PREP2LIVE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PREP2LIVE Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Creeper Drive?
    Posted: 02 Dec 2016 at 8:10am
Does anyone remember an option of a Creeper Drive for an Allis B?  Either I dreamed it years ago or read about one somewhere.  The unit had a hydraulic motor that slipped onto the PTO shaft, the tractor was placed in a gear and the clutch was latched in the depressed position. The tractor could be an 1st, 2nd, or 3rd. or even Reverse.  A variable flow valve controlled the hydraulic flow to the motor on the PTO.  I don't recall how a pump was mounted to the engine or if a seperate engine drove the pump.  Anyway, the tractor would go so slow you could set a plant, take a nap, then set another plant. This option could be disengaged simply by throwing the PTO out of gear and then drive the tractor as normal.  Great option for the slow tractor race.  Any ideas where I remember this from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 8:15am
um... if you depress the clutch on a B, don't the PTO stop spinning ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote PREP2LIVE Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 8:43am
Yes it does. What you are doing is uncoupling the engine, but driving the transmission from the PTO.  Give it a try. Latch the clutch in the depressed position with the locking lever, put the tractor and pto in gear and hand turn the pto. The tractor will move.
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 8:47am
Interesting idea whether it was an option or not. Good way to make a hydro static B for those particular jobs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PREP2LIVE Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:00am
Yes, indeed, hydrostatic B.  Only problem is you can't use the PTO for other attachments. Wonder if there is a market for something like that today?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:08am
Kinda sorta off topic but I was at an auction years ago and there was a two wheeled trailer looking outfit that was made from a car rearend.  It had a PTO shaft attached to the pinion through an old truck transmission and a tongue to attach it to a tractor and a hitch welded to the back of it and some chunks of iron hung on it  here and there obviously to add weight. I must have had a dumbfounded look on my face because a guy walked up and said "cant figure it out?" I said nope. He said you leave the tractor in neutral and run the PTO to make the tractor go like H--- down the road, used for pulling wagons to town. Never seen or heard about another one.
Edited by Butch(OH) - 02 Dec 2016 at 9:10am
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:08am
I have a little six foot blade I use for pushing snow that is on going on my B. If you could get a cooler and tough enough hydraulic motor a hydro static type drive would be much nicer for the constant speed and direction changes of moving snow. It would also be nice for moving wagons around.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:55am
Throwout bearing can't have lasted very long.
Wink
I am a Russian Bot
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:58am
I remember seeing a set up advertised like that for a C farmall.Farmall had hyd pump on engine and hyd motor on pto .Was used to set plants .Would not work on AC B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PREP2LIVE Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 10:48am
AHH. I just did a search on Farmall Creeper and found that is was an option on the C, Cub and 200.  Maybe that is where I had seen it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PREP2LIVE Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 11:08am
Has anyone seen a hydraulic pump mounted on the front of a Model B crank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 11:12am
some here did that , pump up front, for a loader.....long,long time ago...I remember cause I 'borrowed' the pictures.....
and I finally clued into the setup....
B engine drives pump that powers the motor on the pTO shaft that 'backfeeds' the tranny and rear wheels.......
sigh....getting old sux...
Jay
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 12:15pm
This sounds like a cool idea!! If I get to try it one day, I'd get a B, mount a front pump driven from the crankshaft, just pull the shaft running from the torque tube, then mount the hyd motor on the PTO. To make it fun, remove the right fender and add a small side consol with a hydrostat control from a Gleaner! That would be a fun tractor!
I'm trying to think if there's another way to mount the pump some other way so the engine could still run the PTO....
Post Options Post Options   Thanks (0) Thanks(0)   Quote PREP2LIVE Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 1:54pm
Hey jaybmiller, any idea how they coupled the hydraulic pump to the crank pulley? Face it off and bolt on a coupling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 2:42pm
Put an automotive power steering pump on B and run with belt.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:26pm
As you probably know with my father we sold the B for the life of the tractor - 37 - 57.  We sold so many B's that we were a target for after market items for the B.  I do not recall anything like you suggest.  That said, lots of people did many things to the B - including us - to adapt them for "special Operations".
The only thing I can suggest would be the Sherman over and under transmission.  That could make the B slower.
Let us know how it goes.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:43pm
Could you tell us about some of the things you did? I'm sure others would like to hear your stories as well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PREP2LIVE Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 6:55am
Bill Long,
Thanks for your input. Your association with the Allis B over the years is a valuable resource. Now I know that what I remember was not a factory option. Looking forward to stories about "special operations" for B's. Jeff
