190 xt Hydraulic line leaks |
slip knot
Topic: 190 xt Hydraulic line leaksPosted: 22 Nov 2016 at 8:12pm |
last year I got the XT running with a new clutch and rebuilt the power director. While I had it apart I rebuilt the hydraulic controls and replaced the orings in the line connectors. Last week while loading hay I found a small stream of oil coming from the hydro controllers. Where the lines go into the connectors. These were a real pain to replace the orings and I really hate to go back in there
without any assurances it will fix the problem. Are these orings "special" proprietary seals? Is there a replacement end for these lines or do you have to replace the whole line?
I plan on keeping this machine and want to fix this issue once and for all. What would the good folks on here recommend?
MACK
Posted: 22 Nov 2016 at 9:22pm |
Replace the lines with later style lines. It is a never ending job replacing Owings + a real pain. MACK
slip knot
Posted: 22 Nov 2016 at 9:46pm |
are the new style lines available from AGCO? Aftermarket? I'm not sure I want to start trying to piece together a set from junkyards.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2446 |
Posted: 23 Nov 2016 at 7:33am |
No aftermarket, I'd try to get a set from a 200 out of salvage.
DrAllis
Posted: 23 Nov 2016 at 10:56am |
Those old design lines/connections were a really bad idea. I've always thought there was some door-to-door peddler that showed up in Milwaukee one day and sold A-C a trainload of those things for pennies apiece. They sure didn't stay with them very long.
