Off color, green combine question
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Topic: Off color, green combine question
    Posted: 15 Nov 2016 at 1:21pm
I know some of you guys run green combines and I remember seeing a green and yellow GPS antenna on a silver one someone posted a pic of so I thought I would ask here.  We Just bought a Deere 9550 Maximizer that has the wiring harness for the Greenstar system in it but no monitor.  What do I need to buy to get the bu/acre and moisture?   Someone told me I needed a "brown box" display but apparently they are obsolete and no longer available from John Deere. I don't care about field mapping or downloading data just bu/acre and moisture.
Neighbor has an Ag Leader PF 3000 display that that he pulled out of a 9500 combine that had an engine fire before it went to the scrapper that he said I can have.  Anyone know if an AG Leader display can be made to work with the Deere wiring and sensors or would I have to buy all of the AG Leader sensors and wiring?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 1:55pm
We (not me, I just help) have a 9650, but I don't run it much. It had what you're calling the brown box. It worked good and did just what you want. I think now he's running a 2630 which does all the mapping, variable rate, and other goodies.
I would try and find a used brown box somewhere because Deere would easily support it.
I'm not sure if the Ag leader would plug right in. It's hard to beat free.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 2:30pm
several around here have that bu/acre and other things they do. and a friend of mine was riding with his renter that had that, the operator was showing him everything it did. but when the time came to sell the grain, the monitor and the elevator receipts were no where close. that renter doesn't farm his ground anymore for that reason. (land owner was telling me this). so I don't know if they hafta be calabrated each time you change crops or if it's all pre-set? find out before you spend the time and money.
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 2:44pm
http://www.tractorhouse.com/listings/components/ACDetails.aspx?OHID=176035&Manu=JOHN+DEERE&ftcatid=1112
is this the one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 2:46pm
https://www.machinerypete.com/details/other/2007/john-deere/original-greenstar-display/19202149
maybe this one or is it to new?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 2:48pm
https://www.machinerypete.com/details/other/2008/john-deere/original-greenstar-display/18706057
one more
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:36pm
Yeah I think that is what I need.  I wonder why one of them is priced so much higher than the others?
mo 180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mo 180 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 7:49pm
you do need a brown box on a 50 seris. there is plenty of them out there. Ag Express will rebuild them for a set fee. As far as the Agleader you will need their moisture sensor and wiring harness for sure. I'm not sure about the mass flow sensor.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 8:29pm
I think they have to be calibrated often, on the ones I help with we are doing it just about every different field.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:43pm
The Agleader we have in our R62 needs to be calibrated regularly. If you wanted you could get it to read whatever you want. It's a reference but far from gospel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:59am
Our get calibrated every year at the beginning of both corn and bean I think, but maybe it's just one crop. You have to combine and weigh a couple hoppers then put in a calibration factor. Usually find someone with a truck hopper with a scale on it.
HA just realized that one of those for sale on tractor house is from my local dealer.
D17JIM2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM2 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:34am
Calbrate each crop every year if you want closest accuracy. Use a weigh buggy.  They are very good reference if calibrated but still a reference only. My experience was as an ag retailer with different systems.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 11:37pm
check ebay and the newagtalk.com classifieds for a used brown box.
I saw one sell with a ITC globe as a package for 1400 a week ago at a farm sale.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 1:50am
I just saw what they called a "brown box" sell on an on-line auction for $50. I don't know anything about them. just saw it and remembered ya'll talking about one on this forum. don't know if that was a good buy or not?
This page was generated in 0.083 seconds.
