Nelson Mufflers For D-14 & D-15
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Nelson Mufflers For D-14 & D-15
    Posted: 24 Oct 2016 at 9:19am
Where can I get them?
Thanks & God Bless
Dennis
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 10:20am
If anyone can help Dennis, I'd also like to find one for a CA.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 10:21am
I don't think you can. I hunted for then about a year ago now and couldn't find them. The serries 1 mulfer that stiners sells for the d15 and d17 is junk sounds all high pitch tin and is little more then a straight pipe with a bigger pipe around it and holes between the two. I ended up ordering the serries 2 mulfer they offer oval. It requires you cut a hole in the hood and that you put a mulfer adaptor pipe into the manifold but it sounds much better. Not sure how much quiter it is but it is much lower pitch and sounds good. So that was my solution to my 2 tractors they got one of the factory upgrades to serries 2 just about 60 years later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 10:31am
For the B C and CA, those polished stainless mufflers have the same construction as a Nelson. I think if you check with Tony Carbaugh he has a muffler that's built like a Nelson inside but doesn't have the hood on them to go down over the manifold. Seems like he adds the hood part. I'd check with Tony and see what he can do.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 11:44am
 We do  modify  a  muffler  to  mount  like  a  walker  & nelson ..  Lots  of  baffeles  in it.       Tony
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 8:26pm
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 8:33pm
Originally posted by Acdiesel Acdiesel wrote:
not to knock tony, but here's a link to nelson:Nelson Global Products | Mufflers • Silencers • Exhaust Tube - Overview
 I send them an email this morning with all the model number from the B - D17IV.
Thanks & God Bless
Dennis
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 10:00pm
     PM Rick.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 1:27am
The ca Nelson mufflers that djs sells will also work on a d14-d15. Just have to make 2 small cuts to bend the bottom of the muffler around the manifold. You won't see them unless you take hood off. A friend of mine has a stainless one from djs on his d15. Sounds just like a original Nelson.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 5:45am
It works good.  I just had to cut the mounting hole out a bit for a d12.  Doesn't quite sound like a Nelson, but way better than stanleys. It was worth the extra cost to look and sound similar to the original.
Cernunnos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cernunnos Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 11:57am
Hey Dennis,
You might want to call Nelson Global Products as they did not answer my emails last summer but responded right away when I called to get my Nelson CA muffler.  They check to see if they have any on hand or when the next production run will take place.  As they are a wholesaler, they had to ship it to one of their distributors.  In my case, they sent it to Cummins NPower in White Bear Lake, MN but I am sure they will tell you their closest dealer to northern Illinois.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 8:06pm
Dennis:
I'm also interested in a couple of these. Please let us know what you find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:09am
http://www.simplyfilter.com/05388t-nelson-global-products-muffler-p/05388t.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:58am
Ted:
I'm pretty sure that the muffler in your link is for the WD/WD45 and early D17 tractors.  The Nelson #04566T is the one that fits the late B, CA, D10, D12, D14, and early D15.  I've run into trouble finding this one in the past.  The last one I bought was one of the old style Walker mufflers which has been OK, but I don't think the quality was as good as a Nelson.
Edited by BrettPhillips - 31 Oct 2016 at 9:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:29am
If that was a source for WD45 Nelson mufflers, why wouldn't it also be a source for all Nelson mufflers?
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:34pm
I'm also in the market for a muffler for a gas Series II D-15. Is there a Nelson for this? It's an oval shape.
snowman(MI)
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:05pm
For some reason only the round ones are available. Have not heard of any oval "Nelson" mufflers still being produced unless you find some NOS in a box sitting somewhere
This page was generated in 0.119 seconds.
