Do I have to drain the oil??? |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7531 |
Topic: Do I have to drain the oil???Posted: 23 Oct 2016 at 8:21pm |
In the next couple of weeks I am going to be replacing the outer axle seals on my 190XT and the rockshaft bushings and seals as well. Will I need to drain the transmission or final drive oil for either of these jobs?
Appreciate the feedback. Hoping I don't have to drain either one, but don't want to make a big mess either. |
chuck (WI)
Joined: 07 Feb 2010 Location: wisconsin Points: 200 |
Posted: 23 Oct 2016 at 9:38pm |
I didnt and I replaced axle seals on 3 of em and no oil came out no need to drain for rockshaft bushings unless you remove the housing.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 24 Oct 2016 at 6:51am |
If the final oil was never drained from time you bought it ,would be a good ideal to drain and put in new .
DSeries4
Posted: 24 Oct 2016 at 8:37pm |
Thanks fellas. The final drive and transmission oils were changed a few years back when the transmission was rebuilt, has seen little action since then so I should be in good shape.
