Weird problem got me stumped (SOLVED)
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Weird problem got me stumped (SOLVED)
    Posted: 21 Oct 2016 at 6:48pm
My B was running great.  Then, it kept stalling after running rough for 30 seconds or so.  Now it will pop off, but won't stay running.  It is backfiring through the carb a little.  Tractor never gave me a problem before.  It has a distributor, not a mag.  Checked the following:
Fuel flow to carb--good.
Pulled carb, cleaned jets, set float to spec--good.
Checked power to coil and points--good.
Changed condenser (with one of unknown quality).
Bypassed power to coil--no change.
Set timing.
I'm stumped.  My only two guesses left are:
1. Condenser is bad and old one is bad too.
2. Governor weight flew off?  No chunking sound coming from housing.
Weird.  This tractor always starts quickly and has never given me a problem.
Edited by Hubnut - 21 Oct 2016 at 8:35pm
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 6:53pm
Well does it have spark? When you pull a plug and lay it on the block connected to wire
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 7:07pm
Lose an intake gasket?
got oil pressure?- camshaft drives oil pump
Coil gone bad and works only with no compression?
 gas got water in it?
distributor pointer got a crack?
 cap got moisture in it?
Spark yellow? Red? blue? long arc or short?
 If you just filled it and dumped diesel in it...
 Just a bunch of thoughts of possibilities... along with a bad condensor. New ones don't last very long these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 7:12pm
does it restart after it cools off ?  If yes, install new coil and condenser.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 7:12pm
It is a timing issue. The drive pin that holds the gear on the bottom of the distributor may be sheared.Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 7:57pm
Never really gets started well.  It putt putts--cool or hot.  Never STAYS started.  Timing was spot on when I checked it.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 7:59pm
I put a coil on it from another running tractor, but it didn't change a thing.
1940 B "Lucy"
1972 314H
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 8:07pm
I'd pull off the valve cover and have a look.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 8:18pm
Neighbors gas power water pump was running lousy. Would only run with choke on. The thing was making oil- oil level was rising and thin.
Problem was one of his helpers put a good amount of diesel in the 14 gallon tank. So, engine was not getting enough gas and therefore would only run with choke on as compensating fix. But all that diesel needed a place to go. I guess it washed past rings into the crankcase.
Drain tank and refill with gas, cured.
So I say file this one under "fuel not good".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 8:35pm
Thanks everyone for the suggestions.  I ran out to the shop and found a new condenser--Not AC,  (for an international 404 I used to have) but I tried it.  Put it in and she started and ran great again.  The condenser in this can't be more 3 months old!  Where do you get good condensers?  Maybe it's time to convert to electronic?
1940 B "Lucy"
1972 314H
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 8:45pm
Steve...Talk to Steve at B&B Custom Circuits. His number is in the advertising section. Rick
JD Dan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD Dan Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 4:28am
HUBNUT- try STANDARD
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 9:11am
If you go electronic go negative ground at the same time. The electronics are just more robust in negative ground.
