7580 wont move
Gary7580 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary7580 Quote  Post ReplyReply Direct Link To This Post Topic: 7580 wont move
    Posted: 17 Oct 2016 at 6:02pm
I have a 7580 its a 1981 with 2082 hours on it. I'm in the process of painting it and fixing it up. One day I went to start it up and let it run for a little bit and notice my rear pto wasn't spinning. I put it in gear and nothing. I tried different things but nothing. I hope its not the torque limiter but if anybody has other options please let me know, thanks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 9:45pm
Will it steer? Will any shaft turn going to rear boggy turn? Sounds like TL hub or splines in PD. If it steers, PD. If no steering, TL.    MACK
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 10:21pm
welcome to the forum, Gary. Too bad you had to have troubles with an allis to bring you on board, but you come to the right place for AC knowledge. Darrel
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 10:24pm
Hmmm sounds like my 7580. Moving one minute dead the next. Mine steered fine and hydraulics functions. Currently in 600 pieces. Hopefully she will be back going before Halloween. Mechanic thinks the coupler going into the dropbox failed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 6:29am
If couppler in dropbox failed, front would pull but rear would not. Stripped splines out of PD clutch.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 7:07am
My 7580 is down has been for 5 or 6 years now, with something locked up in the transmission. Been saying that I am going to fix it next year ever since it happened, and I guess next year just never comes, or something like that anyway. I sure do miss that old girl. It's not a real power house, but it's just plain fun to operate. I pulled a 24 foot concord air seeder with it mostly, but where it really shined, was on my 1,000 gallon, 100 foot flexi coil sprayer. Just rode so smooth. If I get er going again, it'll be my planter and sprayer tractor. Darrel
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 9:32am
second the drop box coupler.  ours did this,  can be replaced by pulling rear cover of drop box which contains the hyd pump and gearing for rear pto shaft.  the top gear stub shaft splines are bad or the coupler is bad.  ours was just the coupler.  can be done with cab on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 12:32pm
Mechanic came back today. Dropbox was ok ends up shaft going from tranny to dropbox failed. So now we go tranny searching.
This page was generated in 0.266 seconds.
