It's Alive (again)!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: It's Alive (again)!
    Posted: 17 Oct 2016 at 4:58pm
After a year long hiatus my new and improved 190XT roared to life today.  Got it back from getting rebuilt in May and finally got it to a point where I could run it.  It has a Reliance major overhaul kit with AGCO rings, Reliance valve train, brand new turbo from A&I, a couple of thousand spent on head work and welding/grinding on the crank shaft, rebuilt Roosa Master pump set 10% over stock and new injector tips.
You didn't hear it before.  Needed ether to start, it sounded poor and only mustered 77 hp on the dyno before.  Sounds pretty good now, don't you think?
Here is the temporary set up.  Crude but effective.  Next big task is pulling the wheel centers to change the axle seals.  I'd like to have it all finished and together to do some cultivating in the spring, and put it back on the dyno at next summer's show.
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 5:23pm
looks very nice, keep up the good work ,and keep us updated !
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 5:59am
Looks like you've been working since I was there.  It's a good feeling when they run again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 7:05am
Looking good!
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 7:17am
I see a major problem and the problem is its not sitting in my shed.
Looks great!!!
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 5:30pm
Myron you have done a great job restoring your 190XT. Congratulations.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 8:32pm
Thanks Fred, it's not finished yet.  There is still lots to do.  It all takes time.  Being laid off for 6 months earlier this year is the only reason the tractor is this far along.  I don't have as much free time now that I am back at work.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 8:49pm
Kind of a trade off, less time, more money.
Allis Express participant
