D-17 hydraulic leak? |
farmboy59
Joined: 15 Mar 2016 Location: Gobles Michigan Points: 29 |
Topic: D-17 hydraulic leak?Posted: 14 Oct 2016 at 8:49am |
I have a 59 series one D-17. It has a hydraulic fluid leak and I can't tell where it's coming from. Where it's coming out of is the inspection cover in the torque tube behind the flywheel. Just trying to figure out what I have to do to fix it. So far I just keep oil around to keep the level up so I can use it.
DrAllis
Posted: 14 Oct 2016 at 9:08am |
If it's the round cover on the right side, there's a gasket on that plate. If it's coming from behind the side panels, you'll have to remove the side panel to see where it's coming from.
bigredisb
Joined: 16 Aug 2016 Location: Racine WI Points: 185 |
Posted: 14 Oct 2016 at 10:27am |
The other thing I use for hard to find leaks is to put uv dye in the oil that you think is leaking and run it, then check with a UV light. Gives you a perfect look at where its coming from. You can get it at any parts place around here.
1961 Allis-Chalmers D15
1949 Farmall Super A |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2434 |
Posted: 14 Oct 2016 at 12:36pm |
Seal on the input shaft going into the transmission?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7570 |
Posted: 14 Oct 2016 at 9:41pm |
Could be the rear main seal of the engine or the front seal in the torque tube. I usually replace both whenever I am in there. You will need to split the tractor behind the engine. It is also a good opportunity to check out your clutch assembly. |
