Allis 160 hydraulic trouble
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Allis 160 hydraulic trouble
    Posted: 12 Oct 2016 at 7:08pm
Was talking to a guy today who has a 160. He said he was mowing the other day when it started sputtering (kinda like a bad miss). He said oil was running out of the cap on top of the valve cover in a pencil thin stream. He checked the oil and it was 3.5 quarts above normal.
I don't know what the problem would be. Any of you guys have an idea?
He thought maybe there was a seal leaking in the hydraulic pump and that was pushing oil into the engine?
He did say that after he found oil it was leaking oil from the valve cover cap, and started missing, he raised the brush hog and drove home. I figured if the pump was leaking, the hydraulics wouldn't have the pressure to hold the mower up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 2:21pm
bump
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 2:28pm
The lift pump can leak and fill the crankcase with diesel.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Plowboy33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowboy33 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 4:26pm
6040, 2 WD45's one wide one narrow,2 row cultivators,Model 90 pull combine,8 ft drag disc,3 gang disc plow,3 gang flat bottom plow,8 shank Orchard plow,6 foot sickle mower.All purchased new by my Dad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowboy33 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 4:30pm
The front seal of the injector pump or a bad lift pump can let diesel down in the crank case too
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 9:34pm
When you say lift pump...is that the same as the hydraulic pump? If so, how could it let diesel into the crankcase?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowboy33 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 9:15am
The lift pump looks just like the fuel pump on older cars. is located on the right side of the diesel engine facing  towards the front of the tractor. it pumps fuel from tank through the fuel filter to the injector pump. If its dia-fram leaks then the fuel goes right in the crank case
Edited by Plowboy33 - 14 Oct 2016 at 9:16am
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 3:47pm
If that much diesel leaked into the crankcase, he should be able to smell the diesel in the engine oil, and see that it is thinned out a lot. And the fuel pump and main injection pump are the usual suspects as stated.
The main hydraulic pump could leak also. If this is the case, the oil would not be
so thinned out.
If it were coolant, 3.5 quarts (that must be a dipstick guess?) is half the system, you would see the radiator fluid low, and the engine would have blown by now.
