D19 brakes
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: D19 brakes
    Posted: 11 Oct 2016 at 9:03pm
Can anyone tell me if the brake components from a 185 are the same as the D19?
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 9:09pm
Which components are you wondering about?  The pads, disc and balls are probably the same as they are based on later D17s.  The difference is their location.  185 Brakes are in the rear axle housing of each side.  D19 brakes are the same as 190 - ahead of the rear axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 10:04pm
The bands are the same. As are the return springs on the drums and the balls. The disc lining and band springs are different. Splined drum is different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 2:43am
Ok perfect because my d19 the bands are rotted and I have a parts 185 with good ones so that will work out perfect thanks guys
