Gleaner combine |
combinechris
Joined: 20 Jul 2015 Location: wittenberg,Wi. Points: 424 |
Topic: Gleaner combinePosted: 08 Oct 2016 at 10:46pm |
Anyone ever tow a gleaner combine and how do you remove the axles or unhook them for towing?
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 09 Oct 2016 at 1:17am |
we pulled one home from town once, (backwards about 3 miles). didn't unhook nuthin (gear drive).
MACK
Posted: 09 Oct 2016 at 5:16am |
If it has axel Couplers Unhook Them, You didn't say What model. MACK
combinechris
Posted: 09 Oct 2016 at 6:16am |
It's a model A
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2037 |
Posted: 09 Oct 2016 at 6:43am |
A fellow I knew and was a collector said he used a car dolly. Put the steer wheels on the dolly and pulled it backwards. He had no trouble doing 50 mph with any of them except the E. For some reason it would sway at that speed. Good luck.
VAfarmboy
Posted: 09 Oct 2016 at 9:22am |
We towed a K home that way once. Just put back wheels on the car dolly, put the transmission in neutral and went on down the road with it. |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
Posted: 09 Oct 2016 at 9:33am |
Maybe just pulling forward is when the axle snaps? I still don't really understand how that works.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8667 |
Posted: 09 Oct 2016 at 1:18pm |
Model A has a Truck axle so no way to disconnect driveline...make sure trans is full of lube and don't go 50mph.I'd think 30 would be plenty.
MACK
Posted: 09 Oct 2016 at 10:15pm |
You could always pull the axels on the A. Will need to make caps to keep oil in. Should not hurt to toe it. MACK
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
Posted: 09 Oct 2016 at 11:05pm |
any splash lube gear oil lubed transmission Gleaner can be towed short distances without unhooking anything.
The L, M, and N series with pressure lubed transmissions will lock up and ruin the transmission. On anything with a final drive, its a good idea to disconnect the drive lines. On older ones with a unitized axle, like the A, I would not worry much, just tow it. :) |
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
