8070 fwd Tool
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Topic: 8070 fwd Tool
    Posted: 24 Sep 2016 at 10:58pm
Have a leaking inner planetary seal on the fwd on my 8070(the one just after the ujoints).
Based on the service manual and the person I spoke with, it will be an involved job. I was also warned that the big nut that holds the hub on can be a pain and takes a special tool. Anyone have pics of this tool? Or is there another way to get that nut off? Already have the seal, just needing to make sure I have tools so downtime is minimal. Any other suggestions/advice welcome!
EDIT: It is the large seal on the inner hub that is leaking, not the one at the ujoint itself.
~Warren
Edited by Acfarm - 25 Sep 2016 at 12:06am
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 11:10pm
If its the input seal leaking behind u-joints like you are describing, you can replace that without removing planetary, unhook tie rod, turn assembly to one side, remove u-joint assembly and you can slide the input shaft out and replace seals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 12:01am
My description is pretty bad... I keep forgetting that seal by the ujoint itself.... Unfortunately the leaking seal is the next one on the hub Cry Edited original post, thanks for the clarification.
~Warren
Edited by Acfarm - 25 Sep 2016 at 12:07am
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 7:09am
I borrowed the tool from my local dealer. The service manager told me I would likely have to cut it off with the torch...long storey....I had to cut it off with the torch as some one used red Loctite and a lot of it to hold the nut in place...the nut cost about three times the price of the seal, and they had it in stock!
Tool looks like a truck axle nut socket but round and has three or four pins sticking out of it if my memory is correct
sason View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 11:10am
Use a punch and hammer to remove. Then when you have the nut off build a socket for it.
180 with a turbo and 460 loader.
rob(ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob(ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 5:12pm
Threads are a friction fit. Something like 12 tpi on the nut, 12 1/2 on the hub. Makes for a REAL tight fit, Will fight you both off and on, but won't never come off on its own. Do not remove the dust shields unless absolutely necessary. They are staked on and a b!tch to put back on without warpage. Made my own tool from heavy wall pipe to fit on an impact wrench. Sorry, no pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 11:23pm
Thanks for the advice! I will get a chance here soon to dig into it......
~Warren
