160 puking oil out around shift lever
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 160 puking oil out around shift lever
    Posted: 24 Sep 2016 at 8:40pm
I have noticed oil on top of the tranny of my 160. Today while going down the road I looked down and seen oil coming up around the shift lever. Seems to only do this at higher rpms. Bad shift boot or worse?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 12:09pm
Uncle's 185 does the same thing. Says there is a seal on back of trans case that separates it from the next one and that is a split job to replace seal.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 12:24pm
How does oil get to the lift cylinder on the 160? On the d serries there is a hydraulic line that goes to the lift cylinder and if that line brakes it will do what you discribed when you try to use the lift. I am betting your hydraulic oil is low.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 2:42pm
If both compartments use the same oil you can do the poor mans fix and connect both together with a hose/fittings so that the level will stay the same in both.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 3:39pm
There should be a vent for the trans and hydraulic reservoir, if plugged it will force oil out. Leon
