190 Hydraulics |
Kris
Joined: 15 Mar 2012 Location: Fort Madison Points: 19 |
Topic: 190 HydraulicsPosted: 13 Sep 2016 at 7:35pm |
Hello, I have a gas 190 that I use to mow crp with about 10 hours per year.
Every time I start it the steering is terrible (hard to turn) until it gets warmed up. Today I went to move it and not only was the steering hard, but I couldn't get the 3 point to raise the brush hog attached. When I got unhooked from the brush hog the 3 point would raise, but the steering didn't get much better. I then tried to drive around a bit to get it warmed up and the thing felt like it was slipping out of gear (First time that has ever happened). I change the hyd. filter yearly, but have never changed the hyd. oil. To my rather untrained eye I can see the oil on the dipstick looks to have bubbles, but I am not ruling out water? Think changing the oil would help? Any other ideas appreciated!!! Edited by Kris - 13 Sep 2016 at 7:37pm |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 13 Sep 2016 at 8:46pm |
Never changed the hydraulic oil??? I would definitely start there! Changing the filter yearly without changing the oil is just wasting money.
The screen in the hydraulic sump may also be plugged too because of this. The pump cannot draw enough oil from the sump if oil cannot pass through the screen. |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 14 Sep 2016 at 5:55am |
pump is sucking air. check all suction side connections, otherwise your pump seal may be bad. I had this on my 190xt. pulled the pump off, installed a new seal on the drive end and no more air.
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 14 Sep 2016 at 7:33am |
Yep, as noted above.
Pump moves the steering, makes the hydraulics go up and down and keeps the Power Director plates together. Without it working right the tractor is dead in the water. |
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
Kris
Posted: 14 Sep 2016 at 8:18am |
I looked through the service manual and could not find much info on the sump screen other than a schematic of how the hydraulics flow.
How do I access it, and how should it be cleaned out? Thanks folks!!! |
CAL(KS)
Posted: 14 Sep 2016 at 8:22am |
its it the bottom of the hyd reservoir. drain the oil and remove the bottom plate where the suction tube attaches. unless its an early tractor that still has the inline one behind the frame rail but most of those are changed out.
Edited by CAL(KS) - 14 Sep 2016 at 8:28am |
Kris
Posted: 14 Sep 2016 at 6:44pm |
So I feel like these questions keep getting dumber! Please excuse my ignorance I enjoy doing the work myself, but not having hands on knowledgeable guidance can be tricky.
After doing some internet research I have read people talking about there being two dipsticks between your feet on the 190. I have always checked the right side one that would come right off. I have never checked the left one. I'm guessing I should go do that. The way I read the right is transmission and the left is hydraulics? If this is the case what does the tank under the seat drain (hydraulics/transmission/both)? |
DSeries4
Posted: 14 Sep 2016 at 8:53pm |
The plug under the seat drains the transmission ONLY. The hydraulic oil is in the torque tube. There are a couple of plugs to remove to get all the oil out. One is behind the brake rod that goes across the tractor. The other is on the left side on an angle.
Here is a picture of the sump (the small thing) when it is removed from the tractor. The screen sits on top of it. ![]() |
DrAllis
Posted: 14 Sep 2016 at 10:04pm |
CHECK THE LEFT DIPSTICK !! YOU ARE LOW ON HYDRAULIC OIL !!
Kris
Posted: 16 Sep 2016 at 10:03am |
Well, problem solved!
That was one of the biggest bone-headed mistakes I ever made. Checked the correct dipstick and was WAY low. THANK YOU GUYS!!! |
