B Speedi Sleeve part no?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: B Speedi Sleeve part no?
    Posted: 29 Jun 2016 at 3:48pm
Does anyone know the part number for a speedi sleeve and the corresponding lip seal for a B? The engine is a 1941, so would it have the spiral in the crankshaft? Should I even need a speedi sleeve since it's a later model? I've heard the early Bs need one, but not sure about this one.
Thanks!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 4:07pm
half way down the page is a pic
very hard to see but looks like CR 99149
that number is here  3rd from bottom left hand side
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 4:13pm
later style crank wont need a sleeve unless its worn badly
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 6:58pm
Thanks so much!!
Now, the next question...how do you properly center the timing cover over the crankshaft?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 8:07pm
Thanks so much!!
I have always installed the seal in the cover first. I make a cone out of shim stock to keep from tearing the new seal. after greasing it up well I put the cover on carefully and start the bolts. I eye ball it to center and snug up the bolts. I put several large washers and tighten the front mounting studs and tighten all the rest of the bolts. I then mount the governor and water pump along with the fan and generator.  After the gasket sealer has had a chance to set up I then mount the pivot plate and radiator mount.
The seal is easy to tear and I have done so before using shim stock to cover the step on the crankshaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 9:59pm
Well I removed the timing cover and found this. Is this the spiral you guys talk about? Looks like I'll need a Speedi-Sleeve after all. Is there a trick to installing those?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2016 at 5:57am
I cut a pipe nipple to drive it back over the crankshaft end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2016 at 7:39am
Ok thanks! I'll call Napa and see if they can order a Speedi-Sleeve and rubber lip seal.
