Clarify Transmission Fluid Change D17
JWingerter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWingerter Quote  Post ReplyReply Direct Link To This Post Topic: Clarify Transmission Fluid Change D17
    Posted: 29 Jun 2016 at 12:07pm
Drained (what I believe to be) the transmission fluid from here:
Received about a gallon or more of chocolate milk from this 1.5-inch plug.  (I didn't drink it.)  I was expecting something much darker.  I intend to replace with universal transmission / hydraulic fluid that I can find in farm supply stores.  It should go into the loose-fitting cap just forward of the seat -- the one with the dip stick.  Right?
D17 Series III
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 12:54pm
I'd say that's reasonable if that dip-stick now measures nothing.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 1:03pm
The hex head, about 1 inch across, just inboard from clutch pedal, on top of transmission housing, right?  That is the power director housing.  The transmission dipstick is the breather farther to the right. The transmission uses gear oil.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 6:44pm
That plug is for the power direct clutch pack yes the hex head dipstick and it uses hydraulic oil.
The drain for the transmission is feather back under the rear axel. Transmission is the dipstick beside the shifter and I use gear oil some people use hydraulic oil as there was an update about it. But mine has had gear oil since it was new without issues so I keep using it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 6:47pm
While you are at it there is a drain plug just ahead of the one you pulled in the center of the oil pan. That is the hydraulic pump tank. There is a dipstick for it on the right side of the torque tube beside the belt pullie or belt pullie cover. It probably would hurt to drain that hydraulic oil and replace it as well.
This page was generated in 0.191 seconds.
