7020-Update to R134 A/C System?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: 7020-Update to R134 A/C System?
    Posted: 16 May 2016 at 8:07pm
I bought the tractor with the air conditioning belts cut off. Pump appears to be frozen. Does someone make a kit to update these to R134? How many $$ are we talking for a kit?
Thanks
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2016 at 9:07pm
It could be the compressor clutch bearing frozen also.
All the standard components can be used when converting. Be sure to install anew dryer, The compressor is a standard GM A6 like on the 70's cars and trucks.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2016 at 9:16pm
Fix the compressor, then just charge with 134A. There is no need for a conversion kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2016 at 9:46pm
...put on a new drier too.My 8070 was converted before I got it and pretty sure no hoses were replaced has the 134 adapters on the fittings so the compressor may be original? Workd good but I do think it could stand a t-stat switch.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2016 at 9:47pm
You do want to change the dryer as already suggested. Take all the connections loose and replace the o-rings. They won't stand up to to the 134A. Make sure you flush the complete system. Contrary to air conditioning moguls, brake fluid works fine. Just tape the stem to the can so you won't blow it into system. Then blow the brake clean in until it blows clear and then until dry. Do this for all hoses, condenser and evaporator. Drain all the oil out of the compressor and refill with the correct AC oil. The new will adapt to some of the old but not a lot, and can seize the compressor. Seen it happen but not often. Your expansion valve needs to be changed for one that uses 134A The 134A uses a smaller orifice, so you get a colder operating system. Sounds like a lot to do, but really isn't and it also sounds more difficult but it's not.The added expense of new hoses with plastic liners is also not a bad idea. Hope this gives you an idea of what to get a good operating system. Leon R Cmo
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2016 at 9:59pm
Do A/C work all the time, obviously you'll need a compressor, definitely change out dryer and expansion valve, flush system with A/C flush, fill compressor with pag oil, pull vacuum for a couple hours, and fill er up with R134.
Go to AP Air inc for your parts.
sason View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sason Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 7:16am
i just replaced mine on the 7020 i just bought. compressor was locked up. i went to hycap and got the conversion kit to a more efficent compressor. they also have a kit to replace all hoses also. not needed but is available. i did lines so i should have to worry about it for years hopefully. here is the link to the compressor kit
http://www.hy-capacity.com/index.php?page=Search&partid=3448
180 with a turbo and 460 loader.
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 2:32pm
How many oz of coolant does the system hold? Thinking about getting mine going too. My compressor was unwired. Hooked wires up and it will kick on with the thermostat now but doesnt get cold. What oil do you add?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 2:00pm
Leon you dummy, it's brake clean. Remember, BRAKE CLEAN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 2:11pm
Thought that sounded a little goofy even for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 3:59pm
Steve you're right. I have been know to come up with some strange idears. But what if they work? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:38am
I see a reman pump & clutch w/2 yr warranty from Napa for a 79 Chev Pickup is $175 and a clutch is $90.
Would a pump off a pickup work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 12:40pm
If you're getting an A6 compressor, it should be the same. 79 is in the time frame that the A6 was dropped for the R4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 12:44pm
I've flushed components with brake cleaner before too. I always use my air vac to vacuum out the brake clean when done because compressed air can have lots of moisture in it along with condensation from the evaporating brake cleaner. Once I'm satisfied I've gotten it as dry as possible I add the oil and begin evacuation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 12:47pm
Typically converting a R12 system to 134 will be about 80% of the R12 capacity. When I have converted them in the past I'll start at 50% and then sneak up on how much the system likes best.
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2016 at 1:21am
I highly recommend the Sanden conversion from AP Air, it's got the real Sanden compressor not a cheap knockoff, bolts on easily and work's absolutely amazing. I installed everything myself all new hoses, compressor, and expansion valve. The old girl will freeze you out of the cab, I venture to say that it cools twice as good as it did when it was new. I've got $750 in the setup but it was money well spent!!
