190 gas problem
j birke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j birke Quote  Post ReplyReply Direct Link To This Post Topic: 190 gas problem
    Posted: 10 May 2016 at 7:33pm
Looking at another 190 gas! The problem is the throttle is either idle are wide open. Is this a easy easy fix or what do I need to look at replacing.
25-40, WD-45, D14, D17D, D19G, D19G, D19D, D19D, 185, 190G, 190D, 200, 7000, 7060, and 8030
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 7:41pm
That's kinda how they are, at least the ones ive been on , smooth running but theres no in between ; I just keep it opened up
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 8:05pm
My 190 gas has a very smooth transition through its entire throttle range from idle to full power. It holds any speed without a problem.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 8:38pm
Mine does too.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 8:57pm
A couple of thoughts:  maybe the governor weights are on the way out, or someone put a combine engine in the tractor.  Don't quote me, I am not familiar with 190 gassers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 9:54pm
I would say linkage between governor arm and crab. Needs adjusted or worn out cab. Or Linkage .     MACK
