New AC planter help
Stupratt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stupratt Quote  Post ReplyReply Direct Link To This Post Topic: New AC planter help
    Posted: 07 Apr 2016 at 3:58pm
I just picked up this AC planter and would love to have someone let me know exactly what it is? I'm new to Allis equipment and not sure if I'm right in assuming it's a 333 frame? What are the planter units?
Thanks for any help you may be able to give!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 4:44pm
Look here: http://www.allischalmers.com/forum/forum_posts.asp?TID=77382&title=ac-notill-planter-id-help
 wish I had 2 of those units to put on a 3 point hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stupratt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 5:02pm
Thanks that does look very similar!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 6:18pm
WISH I HAD JUST ONE of these!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stupratt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 6:22pm
Actually the more I look at the pics on your link I see the chain seems to run differently than mine. Wondering what the differences are in the 70 series units?
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 6:41pm
Common drive shaft driven from the transport wheel makes it a 700 series planter.
Never had any of those around my area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stupratt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 6:51pm
Any ideas on the seeder units?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 6:53pm
I have a 6-30 pull type and an 8-38 3-pt. have changed most of those plastic boxes over to the rectangular fiberglass boxes thru the years. the newer style boxes bolt right on where the plastic ones do. keep those plastic boxes out of the sun when not using them. thru the years they get real brittle and break just looking at them! duct tape will help hold them together about 1 year if not broke to bad! and don't waste money buying new lids from AGCO, they'll break the first time you snap them on, and they're $78. each!
if it's the 3 bar frame, it's a 600 series planter frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 6:57pm
oh...and all on my planting units are run off the packer wheel, that can be changed to the style shown here, or the one shown can also be converted to the packer wheel drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stupratt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 7:02pm
Only 2 bar frame...thinking of using it for sweet corn, it came with a bunch of different plates. Do all the 70 series units accept the same type of plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 7:03pm
I'd just like to have a 2 row that will plant without having to plow and disc the ground. My Great Uncles old Deere still works and is on 3 point but it was made over a century ago and has a hard time no-till planting Ermm
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 10:09pm
The units are 72 units. Like Shamless said, most were driven, by the packer wheel. If the frame is 2 bar, it's probably a 770.    IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 10:15pm
the old plate type (other than the air units) all used the same type plate, wheather it be AC or jd, when using the jd plates you need an adapter to go in the middle drive area under the box, the ac plates were made a lot stronger than the jd plates and adapters, but are harder to find. most were made of SS. jd are plastic. the adapters are made of a type of polyolefin. (like plastic) they are still available from the manufacter In Lincoln Ne. (trying to remember the name) can google planter plates and find them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 10:16pm
sorry...a lot of the AC plates were also made from cast iron too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 10:19pm
the name of the factory for the plates is: "Lincoln Ag Products"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stupratt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 7:12am
Thanks for your help! It's nice to know what I have! All I had was the serial number but couldn't seem to find any info anywhere about AC planter serial numbers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 10:53pm
I gots scads of planter plates and adapters for that style planter, also a few of the big plates for air planters.
