Clamp on Dual Hardware for a 7000 question
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Topic: Clamp on Dual Hardware for a 7000 question
    Posted: 24 Mar 2016 at 10:36am
bought a cheap set of clamp on's for my 7000 at an auction for $25! tires are pretty well bald  but I want them for floatation more than anything anyway.   came with 15 J hooks.  Looking at my main wheels looks like I will need 16 total for both. so I will have to buy another J hook. no big deal.    my main question is what do I do for the Eye bolts that I'm missing?   do I remove the clamp nuts and replace them with the Eye nut or put them on the ends? theres not much thread there maybe 3 to 4 threads. another question, anyone know what size EYE bolts (thread size) I need? I don't have a thread gauge.
Thanks!
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 11:03am
I only run 6 clamps per wheel on all my tractors even my 8550
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 11:19am
how do yours clamp on? My tractor has spin outs and there are either 4 holes in the rim castings I could put EYE bolts in. or 8 rail clamps I could put EYE nuts on. I don't see how 6 would work evenly or do they not need to be spaced even?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 11:22am
could I just use the 4 holes in each casting and put Hardware store eye bolts in them? that would be 4 hooks per wheel.
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 11:37am
they make a eye hook that attaches to the rail has 3 screws that tighten to the rail also the way we use hook duels is we take the taps off and put the eyes on the bolts they are 3/4 regular thread Niel
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 12:37pm
You will likely be ordering the J clamp from Unverfeth. You can order the eye nuts from them at the same time. I've used 6 clamps for years without a problem but my brand X tractor only has 12 locks to the cast center. Best to have them evenly spaced. Should have said that my duals are T rail snap ons.
Edited by Calvin Schmidt - 24 Mar 2016 at 12:38pm
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 1:10pm
We only use 4 per tire on our 8050 -- been doing it for years
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 2:11pm
Gemplers also has everything you need, j bolts, eyelets and different kinds of clamps.
Leon B
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 2:34pm
http://www.umequip.com/wheels/dual-and-triple/rear-4wd-t-rail/
Looking around in there at Unferferth Wheel products and you'll find what you need.
I think you'll be fine with 6 bolts on a 7000
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 3:46pm
man that stuff gets spendy real quick.    Think I could get away with 4 on each wheel?  otherwise im going to have $200 in hardware and I already had most of it!
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 4:06pm
4 per wheel is plenty.
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 5:24pm
Used ones are out there hanging on tractors. My 7000 may have some. Put ad in classified. 3/4 inch regular thread.?????
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 5:39pm
I broke an eye bolt last year. Went to a used equipment dealer and he gave them to me. He had several piles of them, pointed and said help yourself.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 6:17pm
I ran 4 per wheel for years and never had a problem. Tighten them good and check them after you run a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 7:34pm
Ok im going to try 4 then. The extent of my use will be a 18ft disk.       Cwhit- great idea I know a place like that im going to try.
allis power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis power Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 7:44pm
We use only 4 on each wheel on 8030 and 8010. It has always worked for us
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 8:37pm
Our 7000 has had 4 on each wheel for 20 years with no issue. You'll be fine.
Making a living farming with and working on Allis Equipment
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 4:47am
Four will be fine, that is what we have on our Deere 3020 and the combine.
If you leave the duals on there all the time just make sure you check the clamps every season because they will work loose and the clamps will pop off.    We have lost a few J- clamps over the years, only had a dual wheel pop off  the combine once when I was turning at the end of a field.   I didn't  realize it was gone until I made another round and saw the dual wheel.
Edited by VAfarmboy - 25 Mar 2016 at 4:50am
