185 questions
ChrisS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Topic: 185 questions
    Posted: 22 Mar 2016 at 8:29pm
1. Why do some intake manifolds have "Allis Chalmers" cast into them and others are just smooth??
2. What's the proper rim/tire combination front and rear to keep the tractor level and looking good/tough??
3. Is there a good way to check for jumping out of gear if you don't have a load to put on it?
Thanks, Chris
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 9:11pm
Question 1, I don't know, would have to look at mine, don't remember if it is on there or not.
number 2,  mine has 18.4 by 30 and 9.5L by 15 fronts, think it looks good.
number 3, get going down hill or fast down the road at high throttle and then back off throttle fast, that should work but not always.
hope that helps a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 9:11pm
2.  18.4X30 rears and 10X16 fronts.   The 10X16 fronts make a real tractor out of it.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 9:32pm
I have 18.4 X 28" on the rear of my 185 with 10:00 X 16" fronts and it looks pretty good and level and I like the looks of it.   Rick
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 9:59pm
On my 180 I put 16.9 X 34 on rear and 10.00 X 16 on front. The 16.9 X 34 came off of a 6080 Allis, cast wheels and the tires were new. It sits nice and level and moves a lot faster on the road. We put a 250 gallon bulk milk tank on a 3 pt hitch deck that I built for gathering maple sap when we are making maple syrup. I have about 700 lbs. on the front end to keep it down. The big rubber makes it roll over the rough ground in the forest or bush as we call it in Ontario. It makes it look like a real tractor.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 10:21pm
I'm pretty sure all the ones with 38" rears from the factory also had the 2" taller front spindles. That throws another monkey wrench in the mix. The one I just bought had 15.5 x 38 rears and 245/75-16 truck tires on the front and sat level. I changed to 18.4 x 28 on the rear and had to change the front spindles to standard for it to sit level with 11L-15's on the front....maybe pointed up just a little yet.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 6:36am
#1 cheeper to cast.    MACK
