Transmission whine on a B |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Topic: Transmission whine on a BPosted: 01 Jan 2016 at 11:36pm |
How much is too much? I know they say the A-C's are known for their whine, but I'm just wondering if there's a way to tell. What causes the whine? My 8N is real quite and when I switch to the B it's a pretty noticeable difference.
Thanks
HD6GTOM
Posted: 02 Jan 2016 at 8:02am |
not uncommon for a b to whine -- uncommon for a 8n not to whine
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 02 Jan 2016 at 8:42am |
Straight cut gears tend to whine when worked. Helical cut gears tend to not whine. Helical gears are more expensive and don't work for sliding gear transmissions. Straight cut gears, especially when worn have a bit of a gap when shifting the load to the next tooth and that makes the whine. Helical cut gears can be made to not have that gap, but in a transmission need shifting clutches.
Gerald J. |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Posted: 02 Jan 2016 at 9:46am |
You don't need shifting clutches for a helical gear transmission. Dad's been farming with Allis helical gears since the late 60's and I have grown up with these transmissions and the only gear jumper we ever had was a D17 that my brother bought and it was that way when he bought it. One trip to the dealer 20 years ago and it's been fine ever since. You get enough wear they will eventually pop out, yes but you could say the same about syncro clutches. Eventually you'll have to rebuild them. I've never seen a 7010 thru 8070 ever jump out of gear and they have no shifting clutches. OK rant over.
Wink I am a Russian Bot |
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 02 Jan 2016 at 10:07am |
Gears to tight whine ,gears to loose roar. My 49 B seems to roar but after 66 years I yes it has loosened up a bit.
CrestonM
Posted: 02 Jan 2016 at 10:37am |
This'n kinda makes a noise similar to your stomach growling when going down the road. Sometimes it's loud, sometimes it's not too bad. I thought maybe it was in the chains in the drop boxes.
Emmo213
Joined: 05 Aug 2011 Location: Amherst, Oh Points: 330 |
Posted: 02 Jan 2016 at 10:06pm |
I think they all whine. Here's a couple videos of mine and the noise the tranny makes.
Edit: forgot to post the YouTube link. https://www.youtube.com/playlist?list=PL2H0fSTNBgwy53XCFK-_qXXs9XdRL3t1u Edited by Emmo213 - 02 Jan 2016 at 10:58pm |
'38 Allis B
'41 JD A |
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 02 Jan 2016 at 10:29pm |
There are no chains in the drop boxes. Only gears.
B's are noisy. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
CrestonM
Posted: 02 Jan 2016 at 10:36pm |
Really? The guy I bought it from (I was 11) said they had chains. Phffft! What an idiot! He said don't hook too big a load on it because it could either twist off the drive shaft in the torque tube or break the chains in the drop boxes. I have yet to do either lol, but I guess the 2nd is impossible!
Edited by CrestonM - 02 Jan 2016 at 10:38pm |
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 02 Jan 2016 at 10:58pm |
With a B it's hard to hook too big a load on it and still get it to move, even though they are powerful little tractors! Hard to break it unless you jerk it hard.
Allis Express participant |
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 02 Jan 2016 at 11:29pm |
you sure that whine ain't coming from the seat?
Lonn
Posted: 03 Jan 2016 at 9:20am |
Gilly
Joined: 09 Jul 2013 Location: Lincolnshire,UK Points: 24 |
Posted: 04 Jan 2016 at 5:51pm |
Just watched your video, my B makes the same sound when you let the clutch out, any idea what causes it? Thanks. Gilly. |
Hubnut
Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Posted: 04 Jan 2016 at 6:13pm |
The first video of you driving it sounds like all my Bs and Cs. The second video where you are feathering the clutch sounds like the pre-load on the forward main transmission shaft has loosened. That is just a guess though. If you start it in neutral and let it idle a bit (20 seconds), then push the clutch in, does it grind when you try to put it in gear? I suppose it could also be the clutch release bearing too.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
Emmo213
Posted: 04 Jan 2016 at 7:34pm |
Nope, never figured out why it was making that noise.
No, the gears don't grind if I let it sit for awhile. That video was taken after the tractor had been running for awhile. Actually I don't think the gears have ever grinded except for user error. |
'38 Allis B
'41 JD A |
Gilly
Posted: 04 Jan 2016 at 8:07pm |
Mine is exactly the same, i changed all of the main shaft bearings as there was water in the housing, the bearing on the end of the main shaft (into the pto housing) had collapsed so assumed that would cure it. But it didnt, not caused any problems so far though. |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12044 |
Posted: 05 Jan 2016 at 6:27am |
My B tranny whines, the IB tranny whines even more and its got all new bearings and races in it.
wdtom
Joined: 08 Dec 2015 Location: Foster, R.I. Points: 74 |
Posted: 10 Jan 2016 at 3:38pm |
If you haven't changed the gear oil in the drop boxes you should consider removing the pans and doing a change, most farmers never did and it can be nasty. Tom
CrestonM
Posted: 10 Jan 2016 at 3:58pm |
I did that last year. Had very little oil in there, with a lot of gunk in the bottom.
Edited by CrestonM - 10 Jan 2016 at 3:59pm |
