Rear main seals
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Rear main seals
    Posted: 22 Dec 2015 at 6:07pm
This is why I say to glue the rear main seals in, I know a lot you guys don't and have got away with it, I'm just saying it might spin at sometime and the oil will start coming out behind the flywheel cover on a WD/WD45.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 6:52pm
Clocking them off from the parting line is an old trick to keep them from leaking (as much lol!)
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:10pm
If you are referring to the discussion on the felt rear seals on the B, C, and CA's it is apples and oranges.  The B's are one piece retainers and the seal is one felt ring that fits tight in the retainer and has to be packed in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:03pm
ED you are right about some seals where installed offset but I was trying to show the seal as been pulled apart and it now now a three piece seal and the center part has spun to a diff angle in the main cap and top seal holder.
Sorry Dick I missed that post on the B/C/CA rear main seal, I was just showing this seal that was in a WD and you are spot on they are not the same type of seal.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 11:24pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 6:57am
So you're saying to glue the felt seal into it's grove? Putting my 45 back together in about a month and trying to make sure I get it right. already watched Don's pan gasket video.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 7:07am
When I was at the Allis dealer we always glued them in. I've always done that on my own projects too. They'll also seize to the crank if you forget to oil them. So let the glue cure first then oil the seal before assembly.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 7:32am
would never have thought of that. Good to know. Thanks guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 10:08am
HOW do I REMEMBER that !?!?  I guess I'll have to write it down somewheres....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 11:09pm
Well....Dad(who knew all this stuff) was long gone when I rebuilt my 45 so my felts are NOT glued! So far so good(5yrs).Don't see the point in redoing it right just for the sake of it so I'll wait till they slip and leak! LOL
