313 flex head
Alex (wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex (wi) Quote  Post ReplyReply Direct Link To This Post Topic: 313 flex head
    Posted: 03 Dec 2015 at 11:10am
Have an Allis Chalmers 313 flexhead for a F3.  The metal pans that slide over each other are wore out.  Went to the Allis-Gleaner Co. parts books, but not seeing these sections in there.  It looks there are 10 pieces altogether.  Any thoughts on where I can get these parts?
Thanks in advance for any advice.
~Alex (WI)
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 11:13am
Shoup but AGCO should have them I would think
Wink
I am a Russian Bot
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 11:22am
I have a set of one piece feather sheets on a 320 head.  Way better -- if you are interested they came from Canada but are easily duplicated.  Located near Medford if you are interested in seeing them
Edited by aras - 03 Dec 2015 at 11:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex (wi) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 11:33am
Found somthing. Part No. 71321798 feather sheet (4) and 71373817 (1).  Not sure what part numbers are for the other 5 sheets?  I've seen a stainless steel set up on one of these heads before, is that what you have on your 320? do you have info for that supplier?
~Alex
Wade (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 12:07pm
Shoup has the SS pieces much cheaper than Agco.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 12:11pm
they are stainless steel but they are like the 500 series and don't meet in the middle.  They are from an AGCO dealer in Canada.  I think it is Amos that turned me on to this idea.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 12:12pm
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 12:13pm
You can sort of see how there is no splice -- the sheet floats under the bar behind the sickle
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2015 at 8:45pm
If the sheets are worn out - better check the ball joints and STABILIZER - the reciprocating action of a cutter bar vibrating back and forth in dirty conditions will drastically shorten the life of any 'feather' system.   4-71373820 and 1-71373817 are the 5 feather sheets u need and 1 -71373824 and 4 71373823 are what you need for the front sheets..
This page was generated in 0.110 seconds.
