hydraulic lift weight limits on WD45 AC.
ldogge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ldogge Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic lift weight limits on WD45 AC.
    Posted: 01 Dec 2015 at 4:06pm
Can the hydraulics be damaged when the scoop refuses to lift the heavy load? Can I still use the rear hydraulics to elevate my grain wagon while the front scoop has tried to lift the heavy load but can't lift farther and I need to empty the grain box?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 5:37pm
No and yes. Pump has a pressure relief in it.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote ldogge Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 6:07pm
Thanks for your reply. I have a front/back valve with a lever which should stop one or the other from lifting. I think the valve is allowing some oil to go both directions regardless of the position of the lever. Perhaps I should replace the valve. I have no idea how old the valve is.
