Rear Mounted Blade Replacement Cutting Edge |
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Topic: Rear Mounted Blade Replacement Cutting EdgePosted: 30 Nov 2015 at 1:41pm |
Does anyone know where I could find a new cutting edge for my Allis blade? I believe the part number is 403578.
Thank You |
Thanks & God Bless
Dennis |
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1726 |
Posted: 30 Nov 2015 at 1:57pm |
The last time I needed one, I got it from CAT. Bolt holes are prefect, just bolt up and it was a fair enough price.
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2157 |
Posted: 30 Nov 2015 at 3:07pm |
I had this question a couple three years ago for some extensions I acquired. As with Michael, I found out that CAT was the only place that carried the cutting edge that would work. Had to cut it down for my extensions and only three out of four bolt holes were in the cutting edge for the extensions, but works. There was a discussion on here about it at the time. Seems someone had a comment about a cutting edge CAT offered that was at a lower price than the one I picked up. Maybe someone will respond about that, or you could find the previous thread discussing.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Posted: 30 Nov 2015 at 4:10pm |
I got one from CAT a few years ago for my SC blade. I forget the part number and don't have time right now to search for my posts on it. Blade was only around $60 if I remember right.
AaronSEIA |
HD6GTOM
Posted: 30 Nov 2015 at 6:42pm |
Your local county road department may have some off their road graders that they consider work out. The ones around here have of lot of life left in them for your purpose
jkoby
Joined: 26 Aug 2014 Location: New Castle, IN Points: 179 |
Posted: 30 Nov 2015 at 8:32pm |
For those that got the edges from CAT, did you go to a local CAT dealer? I am needing one for my blade as well. And $60 sounds much better than the $250 I found online.
And CAT in this case is short for Catepillar, right? |
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10141 |
Posted: 30 Nov 2015 at 8:50pm |
I helped a friend put snow plow edges on his Tucker Speed Mover. They worked better than any of the worn out grader stuff. We did have to adjust a couple of holes.
Dave (NE)
Posted: 30 Nov 2015 at 9:05pm |
Yeah, went to the local CAT (Catepillar) dealer. Seems mine for the two extensions was around $110. But, as I mentioned, seems there was a less expensive alternative I wasn't aware of, but was mention in one of the threads on the forum after I bought mine.
willard
Joined: 20 Jan 2010 Location: Southeast Ne Points: 12 |
Posted: 30 Nov 2015 at 9:43pm |
do you remember did you have to take in measurements of the AC blade cutting edge and hole placement? Thank you
Dave in il
Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Posted: 30 Nov 2015 at 11:25pm |
Earlier post with part #s
http://www.allischalmers.com/forum/forum_posts.asp?TID=23887&title=sc-blade-cutting-edge Part #s from that post: Cat prt# 8d2786 or Cat prt# 7T-1633H, 6'X6"X 5/8 |
AGCO My Allis Gleaner Company
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 01 Dec 2015 at 12:01am |
they offer soft blades and hard blades, the hard ones are more expensive. the soft ones will/should out last us!
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24888 |
Posted: 01 Dec 2015 at 6:24am |
Another option might be to have someone weld on 'hard surface' material. Friend (who welds) did that for his snowplow blade.Just check the 'math' though, might be cheaper to buy a new blade than to have the old one resurfaced......
options, gotta have options !! Jay |
Dave (NE)
Posted: 01 Dec 2015 at 9:05am |
When I did it for my extensions, I just took the extension and the old cutting edge in. They did the measuring and I could compare with what they had on hand to get the correct one. As I mentioned, I then had to cut it down to fit the extensions.
Dave in il, how did you get the search to work so you could find that old thread. Never seems to want to work for me when I try to search. I think I also had a thread started where I showed a picture of what I was doing, but couldn't find that one either. Crazy technology! |
Dave in il
Posted: 01 Dec 2015 at 9:30am |
I used Google instead of this sights search engine. For some reason this sight's search engine is a bit hit or miss when I'm looking for something. Google had your post with pictures listed. I put allis blade cutting edge and got 3 or 4 posts from this and some unrelated stuff.
DennisA (IL)
Posted: 01 Dec 2015 at 9:34am |
Thanks everyone for all the info. Since I have two blades I will order both parts and will post pictures and comments.
Here is the info I found off the Cat web page. 8D-2786 Curved Cutting Edges Part Number : 8D-2786 $112.53 USD Curved Cutting Edge Description: The best curved edge choice is often the impact tolerate through hardened edge. Curved edges penetrate the roadway better than flat edges while carrying existing material forward to leave a smooth even surface. Specifications Serration: Not Serrated • Material: Through Hardened (DH2) • Thickness: 0.5 mm • Width: 6 mm • Weight: 23.49 kg • Machine: Motor Grader Attributes: Where impact and abrasion are low, the thinner edge provides the most economical service. Thicker edges provide added strength and wear material for abrasive or high impact applications. ________________________________________________________________________ 7T-1633 Curved Cutting Edges Part Number : 7T-1633 $68.55 USD Weight : 64.4 lbs. Non-returnable part High Carbon Curved Cutting Edge Description: Curved edges penetrate the roadway better than flat edges while carrying existing material forward to leave a smooth even surface. High carbon edge offers better affordability than our through hardened steel, but has limited impact. Attributes: Where impact and abrasion are low, the thinner edge provides the most economical service. Thicker edges provide added strength and wear material for abrasive or high impact applications. Specifications • Machine: Motor Grader • Serration: Not Serrated • Thickness: 0.63 mm • Weight: 29.33 kg • Width: 6 mm • Material: High Carbon Edited by DennisA (IL) - 01 Dec 2015 at 11:00am |
Thanks & God Bless
Dennis |
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 03 Dec 2015 at 2:07pm |
A buddy with a Allis M100 Grader went to cat for the cutting edge, was not terribly priced either.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
