B engine Rods-quick question
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Topic: B engine Rods-quick question
    Posted: 07 Nov 2015 at 6:11am
Mind blank.  thick side of the rod away from or toward the main bearings?
Thanks in advance
Thanks
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2015 at 7:41am
I will post a picture to help. However in assembly of any engine as you place the pistons in the cylinders you need to watch how the rod goes into the crankshaft journals. The rod needs to be centered in the piston on the wrist pin. As the rod gets close to the journal centered in the piston it needs to be centered on the journal. If this is done the problem is solved. I call it engine assembly details.
The only way to get it wrong is to stick a piston in paying no attention as to how every thing lines up and drive them home.
jange01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jange01 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2015 at 11:49am
The service manual states "The connecting rod is offset and must be installed with the long side of offset turned away from the nearest main bearing"
So to answer your question, thick side away from the nearest main bearing.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2015 at 12:14pm
Manual states that 1 and 3 have the long side of the bearing toward the flywheel, 2 and 4 with the long side toward the front of the engine.  Dick's picture shows this well.  The front of his engine is to the right in that pic.
