D17D pto speed
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: D17D pto speed
    Posted: 27 Oct 2015 at 6:49pm
When the engine is running at the proper high speed, what should the pto speed on a D17d be? I cant seem to get the reflective tape  on the crankshaft pulley to stick. A M&W dyno had a chart that would tell the correct pto speed.
Thanks Randy
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2015 at 6:56pm
549
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2015 at 7:13pm
So, if my math is correct, when my pto is running 650 rpms, the engine is running 1950?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2015 at 7:29pm
540 RPM is at about 1650 engine speed. High idle would be 1950 to 2,000 RPM making the PTO speed in that 650 to 660 range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2015 at 7:32pm
Thanks, I had it on a dyno at the I&I show in Penfield a few years ago and they told me i was a little short on rpms. Will check it out tomorrow.
