7060 PTO Seal
dustinmars View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmars Quote  Post ReplyReply Direct Link To This Post Topic: 7060 PTO Seal
    Posted: 05 Oct 2015 at 8:52pm
Can anyone tell me his to change the PTO seal on my 7060 I noticed some small leakage since I used to tractor to bush hog this year. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 9:05pm
If it is single speed, remove cover and replace seal. If two speed, drain oil, remove bottom cover, remove nut on inner shaft, pull shaft out back, remove 3/8 bolts behind hub, pry hub out as you loosen bolts, and pull hub out. Catch gears when hub comes out.   MACK
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 9:26pm
yep...what Mack says...bush hogging seems to be a little hard on them seals for some reason. have had to do my 7010 a couple times! *hint* when you take the bottom cover off, let drip out overnight...or you'll be wearing a lot of it! (this is ona 2-speed)
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmars Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 9:32pm
Yea I have a two speed
