Fixing distributor shaft wobble?
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: Fixing distributor shaft wobble?
    Posted: 18 Sep 2015 at 2:42pm
I have a distributors off an AC B and Farmall M that have considerable wobble from side to side.  According to the AGCO parts book, there is a bushing that can be replaced.
Has anyone done this?  Is it an easy fix?  Any tips?  I figure I'd put the distributor so it is firing on cylinder 1, mark the timing and pull it.  Sound about right?
SteveC (NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC (NS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2015 at 5:44am
Well Dean, I chose an even easier fix. I sent my distributer to Steve at "B&B" and hardly recognized it when it came back. He does an excellent job!
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2015 at 7:39am
My mechanic had a challenge coming up with the top bushing for the distributor on my B. So, he swapped the top bushing for the bottom. Been running that way and mowing 4 acres weekly for eight years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2015 at 12:02pm
That bushing in the dizzy is one piece originally. You can buy a good bit of time by driving it out of the dizzy housing, cutting it in half, and putting the halves back in reversed. I ended up having to get a rebuilt dizzy for my CA, but it went a good 10 years before I really noticed it was getting loose again.
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2015 at 3:57pm
I did one for a 66 Chevy with mechanical tach drive. Did it in 1975, when the car belonged to a friend. Car is in the garage here now, so it was a good expenditure of energy!
David from jax
A proud member of the Allis Express movement!
               Northeast Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 6:38am
A lot of those oilite bushings are not available anymore. I purchase a long rollstock of it, cut the length I need, and hone it to size after I press it back in. Good for another 60 years. We have exchange Distributor units available on our website if interested. I rebuild em' top to bottom, set em' up on our 504 Sun machine and they're ready to install. Thank you for the mention Steve! Its appreciated!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC (NS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2015 at 6:58am
