Adding fluids for my 7060
dustinmars View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmars Quote  Post ReplyReply Direct Link To This Post Topic: Adding fluids for my 7060
    Posted: 25 Jul 2015 at 1:17pm
Recently got a 7060 for mowing and I need to know where to check/add fluids for  hydraulics and transmission. Thanks!
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 2:00pm
YOU HAVE A DIP STICK IN THE CAB AND ON THE LEFT SIDE IF THE DIFF. HSG THERE 2 SIGHT GLASSES THEY ARE IN THE BACK OF THE TRACTOR  BY THE TIRE. THEY CAN BE REMOVED AND CLEANED.  !!!!!!! JUST REMEMBER THEY ARE GLASS  A 3/4 SOCKET WILL FIT TO REMOVE THEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 6:46pm
Dipstick in the cab is for the transmission. Sight glasses on the rear end are for the hydraulics.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 10:55pm
correct me if I am wrong, but me thinks that on my black belly powershift 7060, there is a transmission oil dipstick that is under the cab, not in the cab, faceing the back end of the tractor, and then the two site glass bulbs for the hydraulic oil. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2015 at 6:20am
NOPE. Dipstick for transmission is always in the cab on 7000 series. 8000 series was moved out of the cab because the cab itself was moved forward a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmars Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2015 at 11:11am
Thanks for the info guys! I do have a dipstick in the cab and two sight glasses. Where would the drain plug be for transmission/hydraulic  fluids? Any recommendation on the fluid I should replace with.  And before I try and clean my sight glasses can you purchase new ones in case I break one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2015 at 2:50pm
Three places to drain rearend-hydraulics. One on bottom of each planatary , and one in between. The trans, depends if a PS or PD. Either one, there is a cover under and to rear of trans with 6 bolts that needs removed and a screen to clean out. Have a pan at hand for there will be oil there.  Most can be drained out of plug on side if a PS or steel line if a PD.   MACK
