O/C New Holland 575
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Topic: O/C New Holland 575
    Posted: 23 Jul 2015 at 9:32pm
baler wont drop the knot on the left side (when facing back of tractor). replaced the bill hook and adjusted the wiper arm and still nothing.
had the same problem on a 336 deere but I cant remember exactly what it was that fixed it but I recall a wire being broker right above the bale chamber
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2015 at 4:10pm
Is it just the tail of the knot left in the slot? If it is loosen the tensionon the bill hook tongue 1flat at a time until the tail drops out.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2015 at 4:52pm
are the tucker arms free
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 9:58pm
My NH 565 had all kinds of knotting issues a while back. The hardest problem with mine to find was the hay dog springs on the bottom side of the hay chamber being worn out. The last owner replaced the top dog springs but not the bottom. With the hay chamber empty check to see that the hay dogs are held back hard against the frame. If they don't hold the first section of the next bale back you can get all kinds of weird knotting problems that come and go based on how thick the hay is.
Also check that the shaft for the knife is actually tight mine was flopping around loose I ended up having them sleeved to tighten them up. Mine where loose enough that I could adjust the knife to the bill hook but when I lowered the knotters to the working height the adjustment was inconsistent and the knot would be stuck on the bill hook.
