Right side Frame Rail removal on WD45
bcorradi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcorradi Quote  Post ReplyReply Direct Link To This Post Topic: Right side Frame Rail removal on WD45
    Posted: 22 Jul 2015 at 8:07am
Hi All,
I'm restoring a WD45 and I'm going to remove the right frame rail to try to fix the hand clutch slop.  Is there anything I should be aware of or be cautious off before I remove it?
Thanks,
Brad
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 10:36am
As long as the Left side is in tact and tight, you really shouldn't have a problem taking it off without any other consideration.  To be sure, throw a jack under the bell housing, to add just a little support, don't take up any significant weight on the jack.
Still in use:
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 12:41pm
Drain the tranny oil as the oil will come out where the belt pulley was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcorradi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 1:34pm
Ok thank you both for the quick response.  I'm restoring a WD45 and I bought two 7/8" ID and 1" OD diameter bushings to hopefully take away the slop in the hand clutch.  Is there anything else I should look at or do while I have the rail off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 2:06pm
Maybe a new seal for the belt pulley. It's a lot easier to change with the frame rail off. Also any issues with the hydraulic pump could be addressed easier. Maybe remove it and clean the sludge out of the sump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcorradi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 3:12pm
Ok thank you.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 4:00pm
I'm with Charlie on the idea of taking the pump off to clean the oil housing, when I did mine there was black sludge on the bottom. Also the best way to clean everything and maybe paint the inside of the frame rail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcorradi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 4:01pm
Thanks B26240.  Where about in MN are you if I may ask?
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 6:28pm
20 miles north of Grand Rapids MN
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 9:43pm
I would pull the pin the lever sets on and make a new one.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcorradi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2015 at 12:47pm
Wow cool I grew up in Chisholm actually.  I heard there was a guy by Deer River that has a lot of Allis parts?
Ok thanks Mack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2015 at 9:25pm
hi,
After doing two WD's recently I would suggest rebuilding (new seals and gaskets) in the hydraulic pump. Also if your going to get the castings cleaned up, I would suggest supporting the tractor (engine and transmission) and pulling both rails. It will make the clean up easier. Yes the seal for pulley too.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 1:25pm
Originally posted by bcorradi bcorradi wrote:
Hi All,
You should be aware that, once you remove one side and clean it all out to correct problems, you'll feel obligated to scrub and paint it prior to reassembly, and then feel the need to repeat on the other side. This leads to pulling the transmission, replacing the hand-clutch and that one noisy gear, new rear end seals, an engine rebuild, new tires, gaskets, belts, hoses, decals...
Removing that one frame rail, consequently, becomes very, very expensive...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 9:09pm
Unfortunately, Dave is right on!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcorradi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 11:16pm
Lol that is completely understandable and i believe it.
