Gasket Question
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: Gasket Question
    Posted: 08 Jul 2015 at 8:39pm
A quick question about gaskets.  I just got my new water pump for my F2, and it has a paper type gasket to mate the pump housing to the block.  I have worked with people of two different schools of thought.
 School 1: put the gasket on, and bolt it down, the bolts will squeeze the gasket material to make the seal.
School 2: Always put gasket sealant  on the paper gaskets, then tighten.
Your thoughts.
Thanks in Advance
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 8:51pm
If both surfaces are flat and clean, the gasket should be fine by itself. Might be easier to put a layer of gasket sealer on the pump to hold it in place though. I have a can of permatex forma gasket (don't know what type but it's near black) that comes in real handy for such things, but only use it on one side.
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 9:07pm
I have always put some type of sealer on both sides of any paper gasket. You dont need alot. A thin coat will be enough.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 9:22pm
Indian Head Shellac works great on paper gaskets.
This page was generated in 0.316 seconds.
