1950s equipment still works
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: 1950s equipment still works
    Posted: 07 Jul 2015 at 6:53pm
I was out with my 1950 WD today mowing hay. The mower is a Allis Chalmers Number 7 trailer mower. It does pretty good for the most part.
This was the first cutting, I could not get to the hay sooner because of my schedule or rain.
It does pretty good on grass. See below.
The Alfalfa was down a little bit. So there was a few challenges.
1. It plugged once in a while. I found by adjusting the angle of the sickle this helped. See the photo below. I set it so the sickle is pointing up a little.
2. I need to come up with a better sweep on the end of the sickle. It works great in tall grass. But in Alfalfa it is hard to see where you have mowed and it seems to clump on the end of the sickle. I am looking for suggestions. The photo below is what I see when I am going through the alfalfa as you can see it is hard to see where you already cut!
I have a New Holland Super 68 that was my Grandpas. I used it when I was growing up. I hope to bale on Thursday before the rain on Friday!
Pastor Mike
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 12:47pm
Sounds like you were enjoying yourself!
Brian-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 12:49pm
Nice to see the "old stuff" still working like it should Smile
EAT BEEF!
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 5:51pm
You know, a lot of hay was put up by a lot of farmers with the "old, antique" machinery.  If kept in good condition, it does just as nice a job as a multi thousand dollar machine, and unless you are doing hundreds of acres, it's more fun too.
Allis Express participant
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 5:53pm
Ditto! With the old stuff YOU actually get to drive! Not a computer!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 8:44pm
 You're doin a fine job there Mike. Back when I had to run the Allis conditioner, it got to be a real pain if somebody's grass board wasn't doing the job. It's nice to have a good gap between cuts to keep the rollers from pluggin up.
 I stood and watched one like that sell at auction about 12 years ago. I didn't think I needed it cause I have a JD #5 with a home made bracket on my WD. Now I haven't even tried to hook that blamed thing up in 7 years and won't ever again probably.
 Sure must be nice to have a trailer mower so you can just hook up and go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 10:46pm
Thanks you guys. Charlie it is nice to hook up the trailer mower....but it is a wee bit of a challenge. The blooming thing is tail heavy. So when I hook up, I have to put my weight on the tongue of the mower toget it down to the tractor drawbar. Maybe there is an easier way that I have not figured out yet! It is not as easy as it looks.
Jim Lux is going to bring me a deflector board and grass stick to try. The one on it is metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2015 at 10:51pm
The deflector board like this one is the one I think Jim is bringing me to try.
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 6:54am
The trick to hooking up that tail heavy equipment is a salvage yard jack mounted on the tail you crank up and down to the level you need.
Pretty cheap also.
   Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 7:11am
Al,
I need to get one of those!
Thanks!
Mike
Post Options Post Options   Thanks (1) Thanks(1)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2015 at 8:34am
Mowed many a acre of hay(broom, orchard) with a WD and a New Idea # 7 trailer mower.
I like the scissor type myself.
       Al
