8010 wont go into 6 the gear...
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Topic: 8010 wont go into 6 the gear...
    Posted: 30 Jun 2015 at 2:57pm
My 8010 wont go into 6th gear, 5th is hard. Still goes into reverse fine. Cant see anything obvious behind batteries, nothing loose, etc. It was fine and just all at once wouldn't go... Shifter is in the gear it represents, in other words it not bottoming out in slot. It is in the gear it shows.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 5:37pm
I am assuming this is a Powershift model.  Sounds to me like the shift cable has come out of its hold downs under the cab.  Pretty easy fix.
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 6:29pm
A zip tie broke inside the console.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 7:32pm
If the clutch pedal isn't coming all the way up, you'll have that. Also, the clutch pedal cable could be the issue.
