AC 5040 Pwr Steering & 3 Point
RedBarnNate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedBarnNate Quote  Post ReplyReply Direct Link To This Post Topic: AC 5040 Pwr Steering & 3 Point
    Posted: 18 Jun 2015 at 6:06pm
Hello!
We are working on a AC 5040.
Customer Complaint:
1 - No Pwr Steering
2 - 3 Point Hitch won't work
What we have done:
1 - Changed hydraulic fluid suction filter and all o-rings on suction tube/cap.
2 - Changed power steering fluid filter and o-rings in remote reservoir under hood.
3 - Resealed both hydraulic pumps.
4 - Visually inspected pressure relief valve.
5 - Visually inspected cylinder safety valve.
Where we are now:
1 - Power steering weak when tractor is parked, improves when tractor moving.
2 - 3 Point Hitch now lifts, BUT
    a. With test weights, 3 point hitch oscillates up/down when tractor running and hitch control lever is in max lift height position.
    b. With test weights, hitch slowly drops when tractor not running.
 Important Note: if we adjust the draft control sensitivity regulating lever all the way to the "-", the oscillating is almost eliminated, but the hitch still slowly drops when tractor shut down.  If we adjust the draft control sensitivity regulating lever all the way to the "+", the oscillating speeds up and is much worse, and the hitch still slowly drops when the tractor is shut down.
I feel like I'm close to solving this one, but need some help.
Anyone?  I can get videos/pictures if necessary!
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedBarnNate Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2015 at 7:06pm
Here's a video of the oscillation!
https://youtu.be/08SuEj9D8oA
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedBarnNate Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2015 at 9:20am
Does anyone have experience on these???
tractorman44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman44 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 7:17pm
I'm having the same problem with a 5040 I'm working on. What did you ever figure out on your tractor?
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 8:35pm
Thanks
Please note that the topic you are inquiring about was originally posted over 2 years ago.  You may not get an answer.  Good luck, hope you solve your problem.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 8:39pm
I've messed with the Fiats in branded AC,Long and Oliver a good bit.The first thing is to make ABSLOUTELY sure there is a good seal on the plate where the hydraulic oil screen is located any suction leak there will screw up the whole system.The next thing I'd do is to hook a hydraulic hose into one of the remotes and hold it open to purge all the air out of the system.You can put the end of the hose into the hydraulic oil filler hole.
