Allis G Fan, Generator & Crank Pulley-Not Aligned
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Allis G Fan, Generator & Crank Pulley-Not Aligned
    Posted: 15 Jun 2015 at 11:35am
Hi Guys-I picked up this tractor as a basket case. This are was resassembled before I got it.   I noticed the belt is not running true between the three pulleys. It appears the generator is out of location. Has anyone ran into this issue before? Let me know your thoughts. Thanks.
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 12:53pm
Add some shims to shift the generator position, or its pulley position. The generator is on a bent steel bracket, slot the holes that hold it to the block, or maybe just reverse it. I had to do that mounting an alternator on one of my tractors. Slotted holes worked fine.
Gerald J.
Edited by Gerald J. - 15 Jun 2015 at 12:53pm
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 3:57pm
The pulley may be on the generator backwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 4:34pm
You nailed it. It is on backwards. Thanks.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 4:38pm
Agreed 3. Flip the pulley, you'll be good to go
