WD45D oil pressure
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Topic: WD45D oil pressure
    Posted: 11 May 2015 at 10:25pm
Question for the brain trust.  Where does a WD45D register oil pressure from?  Reason I am asking is mine will have great oil pressure until I start working it hard and it gets warm.
It does not start knocking just concerns me that it has very low pressure.
Thanks
Leonard
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 10:37pm
Oil pressure for the gauge comes from the main oil galley beside the cam. If your oil pressure drops after warming up then I say the cam bearings are in need or replacing. Have you tried turning in the oil pressure relief screw a turn or so?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 10:38pm
Can't really answer that one but I know the 45D's used the bypass oil system instead of full flow. Be sure the stand pipes are in the filters and not drove in too deep as to cover the hole inside.It could very well suffer the same problem as WD's with worn cam brgs causing low pressure.I don't know how the oil flows in the 230 diesel.Someone will have a better response.
...and Don did while I was typing...
Edited by SteveM C/IL - 11 May 2015 at 10:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 11:13pm
Thanks for the quick responses guys, when I get back to the farm weekend after next I will follow your directions.
Leonard
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 11:24pm
Leonard
Leonard I hope you didn't by that 45D from Deer Park that someone had removed the filters on???
ALLIS EXPRESS!
This year:
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 11:46pm
Cam bearings on the 45 Diesel are not pressure lubed, so the cam bearings are not the problem, like Don said try adjusting the regulating screw, it is at the front of the block below the injection pump.
This page was generated in 0.289 seconds.
