Copper line and fitting for Oil Pressure
Allis-Chalmers Damon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-Chalmers Damon Quote  Post ReplyReply Direct Link To This Post Topic: Copper line and fitting for Oil Pressure
    Posted: 07 May 2015 at 10:15am
Does anybody here know a good place to find a replacement copper oil pressure line with the fittings? I bought a new Allis-Chalmers oil pressure gauge but my old fitting split and I would like to get the entire replacement if possible.
Or does anybody know of an alternative oil pressure setup?  I'm working on the 55' WD45 Diesel.
Thanks!
Edited by Allis-Chalmers Damon - 07 May 2015 at 10:15am
1955 WD45 Diesel, 1959 D14, All-Crop Drill, 2015 John Deere 5075e, New Holland 279 Haybine, New Holland 575 square baler, New Holland 1032 Stackliner, 10ft Industrias Disc, 6ft Titan grapple
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 10:28am
Just bought a month ago the copper line with the fittings as a kit at our local autozone store. Had all the fittings plus a few extra sizes that were not needed. About $12. For a D17 IV.
Edited by Stan R - 07 May 2015 at 10:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-Chalmers Damon Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 10:36am
Perfect thanks! I tried NAPA and they didn't have anything....will try Autozone today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 10:43am
http://www.autozone.com/gauges-and-gauge-accessories/gauge-hardware/equus-copper-tubing-kit/39190_0_0/
Part number 9901 $12.99 in stock out here in MA if you want to take a nice drive!
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 10:46am
NAPA does have it, its by the gauges in a kit...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-Chalmers Damon Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 10:48am
Might take the Harley on a cross-country trip haha.
Are these lines fairly easy to bend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 10:51am
Auto Zone is cheaper...
Yes, real easy to bend/shape
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 11:42am
You'll want to be careful if you need to bend the line around any tight radius curves. It's really easy to have the line crimp/flatten on you. Ask me how I know!
Find some round shapes about the needed curvature and bend the line around same. Or get hold of a line bending tool; the parts stores should have them.
WC, CA, D14, WD45
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 9:51pm
if you look on ebay they have them and are around 8-9 bucks free shipping, just bought one about 2 weeks ago for the 615
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2015 at 5:28am
For that small of tubing, an aresol can works sweet for making bends that are nice n' smooth...
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2015 at 7:47am
Two things to watch when you replace/build that oil line, use steel line and bend a full 360* round loop and re-bolt the line to the air cleaner mounting bracket.
This page was generated in 1.102 seconds.
