help with G
pete99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete99 Quote  Post ReplyReply Direct Link To This Post Topic: help with G
    Posted: 17 Apr 2015 at 3:33pm
  So first post on here, hoping to get some advice.  Trying to get a G running thats been sitting for about a year and a half.  There are a lot of variables right now and its not starting, but my biggest concern is that when I crank it, oil shoots out of the air cleaner(Ive got the hood off).  Wondering what that indicates, so that I can take care of that and keep working towards getting it running.  I just replaced the ground cable and it started cranking a lot stronger...but also shooting the oil bath about 5 feet high in the air.  Any advice would be great.  Definitely a novice, but I can give more info if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete99 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 4:01pm
I did have to reset the timing and am not sure if I did it correctly.  Could that be the cause?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 4:09pm
Sounds like you either have an intake valve stuck open or the valves are out of time. I'm not familiar with the Continental engine, but might be ya have to take the head off to find and fix the problem.
 I wouldn't think ignition timing can't make it blow out the intake,unless it actually fires on the intake stroke. Valve timing being off could let it fire with the intake valve open.
Edited by CTuckerNWIL - 17 Apr 2015 at 4:12pm
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 9:58pm
Hello Pete     #1 cyl is at radiator.. Don't have firing order here..   If that don't help might have to pull the head "stuck valve" won't close.   there are several Allis G starting problems in the last week, check them out.    Welcome PLEASE POST FINDINGS FOR OUR INFORMATION!!   Thank You Allen
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 10:06pm
Allen, remember, engine is in backwards! One is at the rear of tractor
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2015 at 7:23am
Perhaps a stupid question, but is the starter original? (Is it turning the engine the right direction)?
This page was generated in 0.073 seconds.
