185 fuel injector removal
kurtleimkuehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kurtleimkuehler Quote  Post ReplyReply Direct Link To This Post Topic: 185 fuel injector removal
    Posted: 13 Apr 2015 at 11:48pm
my friend said It is possible for the injector to break off in the head if I don't know what im doing and I will have to pull the head off. Is this true. What is the procedure? Ty
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 11:55pm
I think the professional method is to use a slide hammer.Easy on an injector that has the fuel going in the top.I would think equal prying under hold down ears would suffice.Just go straight. Some one here will have a better answer.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 8:40pm
never seen that happen, if it is the ac injector and the big line goes in the side of the inj - just remove the 2 bolts and start tapping and prying with some solvent oil around the inj. It will come out - there is a copper washer seal on the bottom, if it doesn't come out dig it out. A screwdriver with a slot cut on the side works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kurtleimkuehler Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 9:57pm
Thank you. I think he meant that what the injector sits in(the sleeve) might come out with the injector, then I would have to pull the head. Is this common?
dieselguru View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dieselguru Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 10:35pm
I'd the copper cup that is fitted into the head comes out its not the end of the world. When this happens it lets all of your coolant into the cylinder. If the cooper begins to come with the injector drain the coolant and remove injector. You will need a special driver to install the new cooper sleeve.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2015 at 6:29am
185 shouldn't have the cups in the head anyway.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2015 at 1:21pm
no copper sleeves on the 185's and if a copper sleeve head does come out - it has to be reamed, and pressed back in with special tool and tested for leaks.... Some of the old heads even had to be resized to accept the new thicker sleeves.
jjpetrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2015 at 2:40pm
The best way for us to get the copper washers out is to screw a bolt a littler bigger into the hole then it kinda of concaves the other way so it slides out easier
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
gerkendave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2015 at 7:15pm
I know on my 190xt I just used two large screwdrivers and just gently wiggled up under the ears. I had one washer not come out and with injpumped as my man of knowledge I used a 5/8 corse thread tap to pull it out. I would imagine a bolt of the same size would work great as well.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 7:46am
The credit for the tap trick goes to this board. I read it on here a few years ago, and just remembered it. Seems it was Mack or DrAllis, or TBran.
