starter cover on hand crank
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: starter cover on hand crank
    Posted: 07 Apr 2015 at 6:57am
What covers the hole for the starter on a hand cranker?  I want to keep my C solely a hand cranker.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 7:06am
I believe that the early hand crankers didn't have a hole at all....
Different torque tube.
my 2 cents.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 7:28am
I concur.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 7:53am
I have seen pictures of the C that were hand crank tractors from the factory, after they discontinued making the torque tube without the hole, that had a cover like a core plug. You could most likely make one out of 16 gage steel. Make a cardboard pattern, cut the steel slightly larger, lay the cut piece on a bag of sand and tap from the center out until you have a slight dome with it sliding in the hole. Probly have to file to fit. You would not need a very high dome, just enough to cause it to expand tight in the hole when you flatten it when in the hole against a stop at the outside. You would need to make a stop inside the hole to install it with the torque tube on the tractor. With the torque tube off you could use a starter drive end slid in from the inside as a stop.
It looked much like the one used in the first power take off units.
Edited by Dick L - 07 Apr 2015 at 7:59am
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 8:48am
Seems it was commented the knock out plug on the back of a WC differential was the same
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 10:02am
Bill is correct - the differential cover from a wc was the same used to cover the starter hole.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 10:05am
Bill is spot on I just looked it up and the rear plug from a WC with ser# 67328 & up out of a cast iron rear end will fit, they have the same part number. AGCO # 70201814
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 10:34am
There ya go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 11:18am
Thanks all.
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 11:29am
I have one that I purchased from Matt(Mn) if you want a pattern.
David from jax
A proud member of the Allis Express movement!
               Northeast Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 12:35pm
I have nos and used plugs for sale. Send me a pm if your still looking.   Thanks Matt
Owner of Matt Scott LLC
http://www.mattscottllc.com/
