B oil leak
mweiland View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mweiland Quote  Post ReplyReply Direct Link To This Post Topic: B oil leak
    Posted: 06 Mar 2015 at 3:05pm
hello, I have a 38 allis b that has some oil coming out through the clutch inspection plate. I was speaking with my uncle about it and he seemed to think you may change that seal from on the crank side without splitting the tractor. I have never done either, and our repair manual is snowed in at the cabin. ? 1.what is the name /part number for said seal. ? 2. do you have to split the tractor to replace it. thanks for any help , Matt
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 3:46pm
You will have to split your tractor. remove clutch/ flywheel/ oil pan and seal retainer. You will need a cork rear main seal a seal retainer gasket and an oil pan gasket
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Post Options Post Options   Thanks (0) Thanks(0)   Quote mweiland Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 7:41pm
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 8:56pm
You might also want to change the seal on the shaft going into the torque tube while you are at it.  I've seen those leak as well.
This page was generated in 0.057 seconds.
