Agco Allis 5650
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: Agco Allis 5650
    Posted: 17 Feb 2015 at 3:32pm
Greetings all,
Anyone happen to have a 4-hole rim for an Agco 5650?  The rim is W11x28, for a 13.6R28 tire.  Agco made a 6 hole model as well, but I need the 4 hole.  It has the z-stlye mounting flanges offset from the center of the rim.
OR anyone know a salvage yard on the east coast that might have one? I have called
Wengers of Myerston (PA)
Frys Machinery (PA)
Tractor Parts Asap
Worthington Ag
Thanks in advance
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Mike Plotner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 4:12pm
might give Anderson tractor in Bluffton Ohio a call, they have a good variety. although it may be a drive
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
tbran View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 8:16pm
unverferth mfg  419-532-3121
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 6:45pm
So local Agco said they could get me a new rim.  $371.  At that price, I figured it won't kill me.  As it was, no salvage yards could find me a used one.  Dealer calls me up and says that it is the wrong one.  They got a rim with rails instead of the brackets that this one has.  To top it all off, when I get the wheel bolts today, they are not the bolts that hold the rim to the center.  I have no idea what they go on, but it is definitely not this tractor.
I have a local guy welding the bracket to back on the rim, so it should be good as new, but will likely cost about the same as the new rim I was supposed to get.  Was looking online tonight, and turns out there is a salvage 5650 in Missouri for $1500, with a hole in the engine.  At that price, I can have parts galore.......
ng5z View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ng5z Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:36am
I just found an inexpensive solution to this problem with my 5650.
This aftermarket 8-loop rim is a direct bolt-on to the original 5650 4-loop wheel center:
http://www.worthingtonagparts.com/Miscellaneous-Rim-13-x-28-Rear-NEW-WN-RW13288
Used 5/8" x 2.88" rim-to-center bolts such as these:
http://www.yesterdaystractors.com/S04352_Bolt-and-Nut-Kit-Rear-Rim-to-Wheel-Center_14587.htm
Origiinal 13.6" x 28 tires fit fine, adds an inch or so width to outside.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 11:22am
Might want to check with Dale at Mayer equipment in Jeffersonville oh .
